Ana içeriğe geç
The Sennheiser RS 120 is an RF wireless headphone system with open, supra-aural headphones.
52 Soru Tümünü görüntüle
Why doesn't my transmitter turn on?
The green transmit lite on my transmitter doesn't
come on anymore to indicate the unit is transmitting.
It isn't transmitting. All connections are ok.
Any advice??
Thanks,
Paul Hipp
paulhipp@aol.com
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 9
5 Yorum
i have an issue where the green light is intermittent at best and these are brand new straight out of the box
it doesnt matter which outlet i plug it into
tarafından
Hey, I have same problem. Have you resolved it, at last?
Thanks,
Diego
tarafından
hey, i have got the same problem
I contacted the service centre and they seem to solve the problem
tarafından
why cant i tune in the frequency on my headset
tarafından
I have the same problem as above - intermittent green light, no transmission. Red light charging OK. Slapped its bottom and green light comes on, but only for a minute or so. Lots of static volume but will not tune in. Would appreciate any help you can give me. Cheers.
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I found this and incredibly it worked for me too!
Just use another power strip
"...I realized an extra device had been plugged into the power strip. It appears the strip may have been overloaded. Tried again with a new strip (careful not to load too many appliances this time) and the green light came on properly."
Bu yanıt yardımcı oldu mu?
Puan 5
3 Yorum:
I tried every input signal and no dice, then I just unplugged and reinserted the power in the same strip. It started working immediately.
tarafından
simple and effective solution. Thanks!
Who would have thought that a power outlet would discriminate power usage? (:
tarafından
Did work for me too! I had this problems many times, and I just waited for it to work... thank you very much
tarafından
Yorum Ekle
No green light?
Disassemble the transmitter and tap the crystal with power on. use non conductive tool !
The crystal is up front and has a shiny case.
I suspect a component value has changed and the oscillator circuit fails to start.
By tapping the crystal it starts the oscillator.
This makes the unit work until power is removed.
…or give the unit a sharp slap with the palm of your hand…that gives same result
..anyone have a circuit diagram to post? I may be able to determine the fault.
Puan 2
Yorum Ekle
We'd had a thunderstorm the other day and our house power flickered - that must be when it stopped working.
No green light with any input. After I unplugged the power supply and then reinserted it the green light came back, we were working again. Phew!
Puan 0
Yorum Ekle
I just had this same issue. Same thing, changing plugs and back fixed it. Apparently, mine took issue with the surge protector they were plugged into. But now the exact same setup is working after getting it to turn on from another outlet.
Puan 0
Yorum Ekle
Hello. I had the exact same problem, and it was solved following the procedure on this page : https://en-us.sennheiser.com/what-do-i-d...
In short :
  • disconnect both power and audio from the base, remove the batteries from the headgear ;
  • let it sit like that for 15 minutes, enough time for the electronics to relax ;
  • then plug the power back in the base, put the batteries back in the headgear, check whether the red "charge" light goes on, and finally plug the audio back in the base.
Puan 0
Yorum Ekle
Yanıtını ekle
Paul Hipp sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 20
Son 30 gün: 74
Her zaman: 12,793
