Rear brake light drivers side wont work
have replaced brake light bulbs and fuses and light will not come on on the rear drivers side when pedal is depressed. right side workd
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Do the parking/running lights work? Starting with the easiest, I would use a voltmeter to make sure the bulb is good (use the continuity setting), then see if there is power getting to the wire using a volt meter. It's possible a wire got pinched, has a bad connection, or got severed somewhere between point A and B.
Good luck!
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 176
