Why is my device not turning on?
I have tried charging my phone, I hold the power button for several seconds... it is just not turning on.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hold volumn down, home and power button together
it should display a service screen from here you can factory reset it
also does it charge??
Bu yanıt yardımcı oldu mu?
Try replacing your battery, this may be due to a drained battery. It happens when your phone battery goes through a lot of charge cycles. Replace your battery (which is placed under the rear case) and trying turning it on again.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 140
I was listening to some music while I was taking a shower and whenever the phone got wet I just wiped the water and continue (this happens everyday) but yesterday there was something wrong for example my battery was 1% so I charged the phone and in 5 mins it reached 42% but of course it did not last long . and later on the phone kept showing that its charging but the charger was not plugged in .at night I plugged in the charger and slept and now the phone is not turning on . what should I do ?
rakan attyeh tarafından
its probably liquid damaged
daniel tarafından
