Why won't my 5D Mk II turn on?
I flip the power switch to the on position but nothing happens. How can I turn my camera on?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
With issues like this, you should really add a bit more info if you can.
Is it a genuine or aftermarket battery. Are you using a battery grip. Was the camera acting up before it stopped turning on. Was the charge status of the battery indicating it was bad in the battery info menu? Was the camera dropped. Was the camera used in an unsuitable environment.
The more info we get the easier it will be to help you out.
A couple of non obvious reasons why it might not turn on...
There is a switch on the bottom of the camera where the battery door is. The camera will not turn on if this is not depressed. The door depresses this when it is shut, so if the door isn't shut quite right, then it wont turn on.
Same goes for the CF card door. If it is not closed and locked into place correctly, the camera will not turn on.
Bu yanıt yardımcı oldu mu?
Check the battery first of all , and make sure the camera is charged. Also check if the battery is inserted probably.
Usually, there are some pcbs underneath the small lcd display, that contain some very small SMD fuses. Fore some reason - bad battery, bad card, power spike, they get blown, and then no power to camera. I already fix a 5D classic having an identical problem. All you need is skill, a set of screwdrivers, multimeter, SMD fuse and soldering iron or station.
Clean metal battery connections inside camera battery compartment. Hope this help. I did it and worked.
A Dah moment.....
I thought my camera was dead also, I kept reinserting fully charged batteries but only flashed the red lamp on the dial.
Then I realized that my card door wasn't fully closed!
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 29
Her zaman: 12,820
3 Yorum
My 5d mark ii has an unusual problem it started last week when I went for shoot I had it in my backpack as I was hurrying to my first shoot so the moment I got there I turned it on and it showed me grey lines on the LCD and the setting menu on the top LCD is not showing aswell ,wat could be the problem? please help.
limpkin tarafından
I have same problem with my camera 5D ii, problem started while i was on set, shooting pre-wedding. Problem started slowly, camera stopped working and i tried to remove all batteries including clock battery and CF Card and it turn back on again. I did it several time and it working again but now the problem get worse, IT STOP WORKING COMPLETE (can't turn on again).
Sorry for bad English it not my native language.
Help please.
Keen Shine tarafından
Hi,
I am having the same problem, I've taken the batteries out, memory cards. restarted.. no power?
Albert Schweitzer tarafından
