Ana içeriğe geç
Launched in spring of 2014, the OnePlus One packs a 5.5" display and runs the Android-based CyanogenMod 12S operating system. Model "ONE A0001."
110 Soru Tümünü görüntüle
The charger won't go into the USB plug, what is going on?
My charger won't plug into the USB port why won't it go in? What can I do to fix it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 16
5 Yorum
It worked had a tiny peice of paper thankyou
tarafından
I Have The Same Problem With The USB To My Wireless Mouse
tarafından
Thank you it worked.
tarafından
Oh thanks very much , it worked a treat.
tarafından
Try another USB port.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I had this problem today. Visual inspection with a flashlight but no magnification didn't show much except that the socket hole was not as deep as it should be. I took the flexible plastic toothpick out of a Swiss army knife and gently scraped the bottom of the socket with the tip. Then I tapped the phone on a piece of white paper and saw some debris (dirt) come out of the hole. I continued this and after I made a good start, a lot of debris came out. Finally, I pulled out a large piece of pocket lint.
I suspect that if a little dirt gets in the hole, pushing the plug into the socket compacts the dirt into a flat layer, and if enough dirt gets in there, the plug will no longer connect.
The solution is to clean the socket out gently with a flexible plastic tool, such as the toothpick in a Swiss army knife, so that you do not damage the pins. To prevent the problem the phone should be kept in a clean pocket, or in my case, where my pockets just aren't clean, I will keep the socket covered with a bit of gaffer's tape when not in use.
Bu yanıt yardımcı oldu mu?
Puan 11
8 Yorum:
I've been struggling with this issue for a long time, thank you for the solution!!
tarafından
Fantastic answer fixed my problem thank you xo
tarafından
Thanku very much for this solution
tarafından
It’s not working I tried and it didn’t work I still can’t charge my phone
tarafından
this was exactly my problem! pocket lint! using a sharp pair of tweezers to carefully dig it out got the job done for me.
tarafından
3 tane daha yorum göster
Yorum Ekle
To prevent any further damage to the usb port. Inspect the port in a well-lit environment. If the usb port looks to be damaged due to excessive force, it must be removed and replaced. If you attempt to replace the micro usb port, please reference the guide linked below to help you in removing and replacing this piece. Should you have an problems repairing the device, please contact OnePlus directly so they can assist you in repairing your device.
OnePlus One Micro USB Port Replacement
Puan 3
1 Yorum:
Change the usb port and see the result
tarafından
Yorum Ekle
Yanıtını ekle
Richard Yankowski sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 50
Son 30 gün: 166
Her zaman: 105,382
