Ana içeriğe geç
A mountain bike released by Trek in 2003
4 Soru Tümünü görüntüle
What is the psi recommended for pumping up the tires?
I know road bikes need like 100psi, but since this is a mountain bike what should I pump them up to?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The recommended psi for the tires on this bike is 40-65 psi. This can be accomplished using a standard manual bike pump or a compressor with a bike attachment. It is important to check the psi of your tires after inflating them.
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
Look on the sidewall of the tire.
Generally mountain bike tires have a lower pressure than a road bike, but it is important to read the specifications stamped on the tire. Also, if you are riding on the road primarily, you might want a higher pressure to fight rolling resistance.
If you are riding loose dirt, mud and that sort of thing, you might want a slightly lower pressure than what is listing as MAX on the tire. This will give you a better handling bike.
If you are riding a mountain bike on pavement, use slicks or semi-slick tires. These usually have a higher pressure. The specifications depend on the type of tire, and terrain.
Puan 2
Yorum Ekle
Yanıtını ekle
Jimmy Todd sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 3,806
