My station isn't charging
Tried to charge the station with multiple chargers, and still isn't charging.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Make sure that you are plugging into the outlet completely, if it is only plugged part way it may not work. It is possible since you used multiple chargers that the outlet is not working properly. You should try another outlet and see if it charges.
Bu yanıt yardımcı oldu mu?
Look in the end of your charging cable. It may have one of the pins that had broken off and extending from the cable end. If this is the case you will need to replace the USB port in the unit.
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 743
