After liquid damage cleanin, display broken. Worth buying new display?
So a water leak had cau
sed some damage to this Macbook Pro, and it failed to turn on at all. After taking it apart and some careful inspection, I found corrosion damage but no burn marks. Cleaned the corrosion damage, and now it starts up just fine, plays sound, responds to input, etc. BUT the screen doesn't turn on. I noticed there was some deeply set corrosion on a component at the top of the logic board that wouldn't come off, so now I'm wondering if it's worth trying to get a new display assembly to see if that fixes the issue, or if there is a bad component on the logic board which makes the display not worth fixing.
Secondary question, what is this component and can I fix just that? (pictures of said component attached)
Bu iyi bir soru mu?
