Ana içeriğe geç
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
151 Soru Tümünü görüntüle
Only background showing and not working, not closing?
I have IOS 8. I was reading a pdf on Adobe last night, my charge was gone so it closed. Then I recharged it. I tried opening it. The background appears. no pass word, screen lock. no apps. no up or down manues. nothing. I tried switchin it, does not switch. I pressed the up and down bottons at the same time. apple logo appears, the screen goes blank, after a while, the same background appears. my own background. Ive tried this many times
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 9
17 Yorum
there is also a stage where ipad opens with clock and date showing as it is supposed to, but the screen is extra extra large and does not reduce. I can open the drop down menu above, still extra large.
tarafından
I tapped the screen with three finger twice, and it opened.
tarafından
I have the same issue and nothing is working not even rebooting it works :(
tarafından
same thing hapened to me, what I did is press and hold the power button and home button
tarafından
Danika, THANK YOU SO MUCH
tarafından
12 tane daha yorum göster
Yorum Ekle
11 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Try pressing home button and power button for like 10 seconds should either power off or reboot if powers off turn back on see if fixes if not plug into computer and see if sees it if does may need to reload os if not might be S.O.L.
Bu yanıt yardımcı oldu mu?
Puan 13
12 Yorum:
thank you. pressing buttnons like that do not help.
tarafından
Thank you it worked I was so worried
tarafından
thank you so much !! life saver
tarafından
it worked!! yippeee!! thank you so much
tarafından
thank you so much
tarafından
7 tane daha yorum göster
Yorum Ekle
I just switched off my phone, then i held the home button and the power button at the exact same time for like 5 seconds then you see a blue screen then it turns black and you will see the apple logo and if it starts its all fine
Puan 3
1 Yorum:
Thank you! My phone is saved :)
tarafından
Yorum Ekle
Are you able to power the unit off? If so, plug it in, turn it off and leave it sit overnight. At least 8 hours. Sometimes they come back from weird errors like after a timeout and a good charge.
If that doesn't work (don't be surprised if it doesn't), then its time for a restore. Plug the iPad into your computer, hold down the power button for 5 seconds. Then press and hold the home button for 15 seconds while still holding power. Then the "connect to iTunes" should appear. In iTunes, select restore, and let the device wipe and install.
If that doesn't work, please update. Its possible that it could be hardware but I'd bet on a software glitch.
Puan 1
Yorum Ekle
I have the same problem. Updated yesterday and it kept freezing up so I shut it down and it loaded with the apple Icon by then only the clock shows. It won't shut down again. Basically the upgrade screwed up my Ipad. Nice going Apple. :-(
Puan 0
Yorum Ekle
hold power and home button at the same time for ten seconds
Puan 0
Yorum Ekle
The same thing happened to me
But what can I do to fix it when my home button doesnt work???
Puan 0
1 Yorum:
I have the same problem too? Anyone can help?
tarafından
Yorum Ekle
Can i get help my friend's iphone not working she cant do enithing. Thanks
Puan 0
Yorum Ekle
try placing it in some fire. when it burns for about 10-15 minutes then out the fire with some honey and try powering it on with a block of cheese. If that doesn't work power it on with a hammer for 8 seconds then toss if off a cliff, by then it should start working.. working well out of you life, so you can then go purchase a better &&^&^$^ device you stupid @%^$$@$!!
Puan 0
1 Yorum:
Wtf? (What the flip)
tarafından
Yorum Ekle
Hi I learned that if you put ur phone/I pad in the microwave for 5-10 min it will solve that problem thank you for every one who told me that.
Puan 0
1 Yorum:
And then eat it. That should work.
tarafından
Yorum Ekle
I don't have an answer but I have a question. I have a Zte Whirl that still works but stays on a black screen. Can you help me solve this problem please?
Puan 0
Yorum Ekle
my phone isn't displaying words just the background. what should I do?
Puan 0
1 Yorum:
This is not an answer :P
tarafından
Yorum Ekle
Yanıtını ekle
nur sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 37,085
