Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
585 Soru Tümünü görüntüle
Maximum drive capacity in optical bay?
I'd like to replace my current 2TB HDD with a small SSD and replace the optical drive with a HDD. Is there a maximum capacity of drive I can fit in the optical bay? I've seen a 2.5" WD 2TB that I'd like to fit, would that be ok?
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The limit here is the drives height. Some carriers can support a 12mm drive most can only support a 9.5mm. As we don't know the given holder or drive details (can you give us what you are getting) I can't offer you more.
You may want to think this though again. One of the issues you will face is the drive's SATA I/O speed. Remember the optical drives port is IDE not SATA so what ever drive you put into it it will be slow and you may in fact have an issue if you put in a SATA III (6.0 Gb/s) HD as many of these converting holders SATA port is only SATA I (1.5 Gb/s) or SATA II (3.0 Gb/s) so the drive may fight the SATA port as well.
If you want speed how about swapping out your HD for a SSHD (hybrid drive) Then you get the zip of the deep SSD cache with the storage of the HD. If you need more space they even have 3 & 4TB SSHD 3.5" drives! Checkout Seagate's drives.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Anthony sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 131
