Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3531 Soru Tümünü görüntüle
Weird no-stereo audio issue on headphones only
This is a weird one! On headphones, all audio sounds like it's out of phase, very garbled and muffled as well.
Whilst debugging I found that if I moved the L - R slider in Accessibility just a fraction off the center, audio then sounds fine but with what appears to be no stereo separation. I ran an audio test track and sounds that should be in L or R channels are all coming through both speakers.
Playing through the loudspeaker it all sounds fine but of course this is two channels being fed through a single speaker so may mask the issue?
I'm lost as to what might be the cause here. Is it worth replacing the dock connector assembly perhaps?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Does the problem occur on other headphones aswell? Because faulty or worn wiring to the earbuds can produce this result. If other earphones sound like they should, you're going to have to buy some new ones.
If the problem exists also on other headphones, first clean the dock connector grom any dust, lint and debris and run some paper towel with a drop of 90% alcohol along the contacts (I do this with a toothpick to get the paper in all corners). Then clean out the headphone connector with a piece of paper towel rolled up on a toothpick, again using a drop of alcohol.
If problem persists, take the phone to a genius bar to get it examined.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
DarrenG sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 561
