Why does the projection clock "on" button keep turning off?
Whenever I turn the projection clock button to the "on" position, it moves back to the "off" position and will not stay on.
Bu iyi bir soru mu?
İptal Et
Released Pre-Fall 1997, identified by model number RM318PA
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz AtınSon 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 5
Her zaman: 211
After some research, I discovered that the unit needs to be reset.
Resetting process:
Remove batteries and disconnect adapter for 15 minutes.
Reinstall batteries and reconnect adapter.
Hold reset button for 5 seconds located in the battery compartment or on the back of the unit.
(A paper clip or pin will be needed to fit into the hole for the reset button.)
Kathy Rowley tarafından
Projection Clock RM318PA Troubleshooting.
