Hinge broken on bottom part of game console
The game console works but the hinge is broken. Need to purchase the body to the system
Bu iyi bir soru mu?
Bu iyi bir soru mu?
The best place for you to buy this is probably Ebay. If it is just the hinge you could probably get away with just replacing the bottom/middle shell...that's the piece where the bottom LCD mounts in. Most of the time you can just replace this piece and save yourself some time and money.
You can get this part on Ebay for about $10-15.
Let me know if you need more help.
Bu yanıt yardımcı oldu mu?
If the plastic is broken you'll need a new skin but you won't use anything but the inside piece. It is really difficult to get the new piece in after removing the top panel. Follow the guide to remove all internals. I had to make sure all buttons were out and off to the side, put the hinge in place, thread the ribbon cables through, and then you'll have to bend the plastic piece so it'll fit and the hinge. Hope that helps.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 405
