Ana içeriğe geç
Amazon tarafından üretilen, 1280x800 HD ekrana sahip Kindle Fire 7" tabletin güncellenmiş sürümü. Eylül 2012'de piyasaya sürülmüştür. Bu cihazın onarımı oldukça basittir.
Keyboard won't pop up
I only had my Kindle Fire HD for a matter of months before the keyboard stopped popping up. I click into a Search Bar (or something else that requires me to type) and... nothing. This obviously limits its function, so now it's pretty much just a dust collector. Any suggestions?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 30
18 Yorum
I was on my KF HD and when I went to aptoide my to update my Kik and my keyboard and my shyt stop popping up someone plzzz help me before I end up breaking my god dam kF
tarafından Paylaş
that happend to me too
tarafından Paylaş
This sucks someone help
tarafından Paylaş
Brandon, Same exact thing happened to me
tarafından Paylaş
It happened me too I have to use a japeniese keyboard ITS SOO FRICKIN ANNOYIN HELP ME PLEASE SOMEONE HELP I BEG U
tarafından Paylaş
13 tane daha yorum göster
Yorum Ekle
17 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I found a solution guys you go to SETTINGS then KEYBOARD AND LANGUAGE the scroll down to CURRENT KEYBOARD and select JAPANESE keyboard that will make the key board pop up but itll write it in japanese but where the "SYM" symbol would normaly be there you can change to engle there will be a japanese symble and A and a 1 put it on the A and go to store then you can type and add a keyboard from there typing problen solved
Bu yanıt yardımcı oldu mu?
Puan 12
11 Yorum:
Thank you so much for the posting, it worked....!!!! problem solved
tarafından Paylaş
This worked amazingly well. Thank you so much. The Japanese keyboard has an English option like Jose said. You just tap on the letter A down in the bottom left of the Japanese keyboard. This lets you type in English. Then go to wherever you download apps and download a new keyboard. This allows you to be able to type,"keyboard," in the search.......The only problem I had afterward was after the program downloaded you have to be able to go back in your settings to the keyboard setting and it was in Japanese So note what that looks like. Then you scroll down the list there of possible keyboards and the one you downloaded will be in there. My new keyboard was on the same screen that the settings was on, so it was easy to find. Anyway you shut off the other buttons in the keyboards and enable the new one you downloaded. This is working great now and the new keyboard is much better than the one I had.
tarafından Paylaş
when I select CURRENT KEYBOARD SETTINGS it kicks me back to the main settings screen :(
tarafından Paylaş
wish I had googled this before I bought a new Fire! Jose it worked and I can at least now open things which had parental control. Thanks :)
tarafından Paylaş
I cant go to settings without my password.... and I can't type in my password without my keyboard... T-T
tarafından Paylaş
6 tane daha yorum göster
Yorum Ekle
Hi. Have you tried resetting the unit?
Resetting your Kindle Fire can solve intermittent problems. To reset your device:
Make sure your device is disconnected from any power source.
Press in the power switch and hold it there for 20 seconds.
The screen should turn off, once the screen is fully turned off press the power button in for 2 seconds and release. The device will turn back on and you will see the Kindle Fire loading screen.
This reset will not affect any books or content you have on the Kindle.
Puan 5
5 Yorum:
Will not work if the keyboard was removed all together. I'm not sure why the keyboard function is gone but still have the ability to log into the password screen to access the kindle HDX 3rd gen but it still works. if you guys need a solution an you already have aptoide on your kindle just search through the available apps shown for Flash Keyboard (no you dont have to type anything) download it (might take awhile ) install it and you're good to go if this doesnt work post and i'll try to give you another alternative.
tarafından Paylaş
Doesn't work im sry but plz if u can help plzzzzzzzzz
tarafından Paylaş
Can't reset when parantal control are on as need keyboard for password
tarafından Paylaş
I cant reset without typing my password in... I need my keyboard for that.... T-T
tarafından Paylaş
just factory reset it
tarafından Paylaş
Yorum Ekle
Install a new keyboard and then set that as ur default
Puan 4
14 Yorum:
My kindle fire hd 7's keyboard won't pop up at all so now i can't even log into it. PLz help
tarafından Paylaş
Cant install anything Keyboard will not pop up
tarafından Paylaş
Ya know, I could do that but there is just one problemo...THE KEYBOARD WONT COME UP TO TYPE THAT
tarafından Paylaş
Swipe down from the top of the screen and tap Settings. Tap Device Options, and then tap Reset to Factory Defaults. Tap Reset to confirm.
tarafından Paylaş
I'm trying to reset it, but I have parent controls and it won't let me reset because I have to put in the parental controls password
tarafından Paylaş
9 tane daha yorum göster
Yorum Ekle
I tried many solutions, the only thing that helped my kindle was setting it to factory default (Settings > Device > Reset to Factory Defaults ).
But you will loose all installed applications, pictures and other stuff.
Puan 1
Yorum Ekle
If you dig through responses, a user named Far Isle explained a PERFECT solution….as long as you can access the main screen. Go to Settings, Device Settings & Keyboard option. From that screen, deselect the US English Keyboard and select another country’s English keyboard! I selected both Canada and UK…defaulted to UK on my Kindle Fire HD 10. For good measure I held down the power button until it shut off and then waited a minute before restarting…now the keyboard comes up and types beautifully! (As it should!!)
Puan 1
Yorum Ekle
P.S. I typed this six weeks ago and no issues since!
Puan 1
Yorum Ekle
I have the same issue. but use the voice button, or Alexa to get somethings done. I can't find the setting for the keyboard.
Puan 1
Yorum Ekle
Change your keyboard's language to a different language
Puan 0
3 Yorum:
This was the best suggestion. Changed keyboard from English US to English Canada, then rebooted Kindle Fire HD and keyboard reappeared!
tarafından Paylaş
Worked! Thank you.
tarafından Paylaş
I did thank you!
tarafından Paylaş
Yorum Ekle
That worked! Thanks.
Puan 0
Yorum Ekle
my amazon tablet keyboard will not pop up what do I do
Puan 0
1 Yorum:
how do I fix my amazon fire tablet if my keyboard will not pop up
tarafından Paylaş
Yorum Ekle
It is just when I click the search bar on any app the keyboard will just keep on glitching and I realy need it fixed
Puan 0
Yorum Ekle
My keyboard kinda does this too but when I play a game called rolox the keyboard doesn't pop up it Only pops up when my battery is low :(
Puan 0
1 Yorum:
Do you mean Roblox?
tarafından Paylaş
Yorum Ekle
Try going to keybord settings and making your keyboard another colther it kinda works
Puan 0
2 Yorum:
cant get to settings
tarafından Paylaş
half screen only
tarafından Paylaş
Yorum Ekle
me to; when I had a software update BOOM for some random reason my key bord stopped popping us amazon plz fix this
Puan 0
Yorum Ekle
I had this issue for my Fire Tablet 10HD (9th edition). Adding a new keyboard worked. I was also able to make it work with the Spanish (Latin American) keyboard so maybe any other keyboard works. With that new keyboard added I was able to factory reses the device (mine needed a PIN to reset it) and the keyboard works great in my original non-functioning language (English) after the factory reset.
Puan 0
Yorum Ekle
Hold the power key down for 40 seconds and let it reset itself. When you switch back on, the bug should have gone. At least this worked with mine.
Puan 0
Yorum Ekle
So check the new comment the person put before you it will help you and your problem -Hope it helps!
Puan 0
Yorum Ekle
Yanıtını ekle
Stephanie Roberson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 145
Her zaman: 77,408
