Ana içeriğe geç
Model A1019 / 10 or 20 GB hard drive / full-size Firewire port
Is there a maximum disk size the iPod OS can support
Hello,
I have a big problem changing the hard drive on my 2nd gen iPod. I replaced the original 10 Go HDD by a 128Go SSD (Kingspec 1.8" CF Solid State Drive (IDE 50pin) (KSD-CF18.6-XXXMS).
I've spent many hours trying to see the disk in Disk Utility to format it in HFS+ in order to prepare it for iTunes.
It takes between 20-30 minutes to mount and then when i lunch the format procedure it takes a very (Around half an hour) to do so until it tells me that it's impossible to write on the last bloc...
So is the SSD faulty here ? Or maybe this old iPod cannot support such a big disk ?
Please help me !
Bu iyi bir soru mu?
Puan 1
1 Yorum
I'd also like to know this. I'd love to swap out the original HD for a SSD.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
The problem you face here is not only finding the HD but one that will fit within the limited space within your iPod.
IDE HD's which the iPod used are not being made any more and IDE SSD are very rare.
The problem you face is the size of the back case the larger drives are higher in height and the back shell was made larger to support the bigger drive on the newer models.
So on the most part you're stuck putting the same or smaller drive in.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
well I don't know of any size constraints but I know there are adapters that let you use compact flash card in them because of the size constraints of the ipod those work great
Puan 1
1 Yorum:
There all too big for the limited space within the iPod
tarafından
Yorum Ekle
I have installed a 256gig SD into a ipodclassic and it works fine.
Puan 1
Yorum Ekle
Yanıtını ekle
JLPicard sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 1,209
