Are the LCD connections the same between the S4 & S4 Mini?
I am just wondering if the LCD connection is the same between the Galaxy S4 Mini and the Galaxy S4?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
No,
The first one is 1080 x 1920 pixels and the second one - 540 x 960 pixels.
Regards.
Bu yanıt yardımcı oldu mu?
A couple of questions, if you don´t mind.
You mention that "The first one is 1080 x 1920 pixels and the second one - 540 x 960 pixels", does that mean that the connectors are different or that it will work with less resolution?
I have an S4 with a broken lcd. I want to enable usb debugging on it, so I can see the screen on my pc while the replacement screen arrives.
I also have an S4 mini and I was wondering what would happen if I plugged the S4 mini lcd in the s4 connector. Can I damage the working S4 mini screen?
I only need to see the settings screen.
Thanks!
No,
the connectors are of similar type, but they are not the same. The s4 mini connector is a bit longer, so it won't fit. It also has more pins.
I don't know if they are electrically compatible. Theoretically, if you somehow connected the right pins, for example by a custom made connector cable .. it might work, or break something.
Regards,
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 962
