Ana içeriğe geç
Why won't my nano turn on?
I got my Ipod nano 4th generation for Christmas about 4 years ago. About 6 months after I got it it had to be reset to factory settings. About a month or so later I plugged my Ipod into my wall charger to charge it and when I got up the next monring it wouldn't turn on at all. Could it be the motherboard or the battery? Please help. I'm in dire need of fixing it.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
What it sounds like to me is that the iPod is not charging or the battery is not holding its charge. First I would check the charger and USB sync cable on both ends and make sure the connections are in good shape and working and that the charger is charging. You can also check to make sure the charger works by trying to charge another device. Then I would check the connector the USB sync cable connects to on the iPod and make sure it is not damaged. If that doesn't working then try using a different charger and usb sync cable to charge the iPod or plug it into a computer and see if it charges.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
kimberly sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 924
