Speaker jack stuck in headphone port - Remove logic board and fix?
The speaker jack from an external computer speaker set snapped off inside the headphone jack of my macbook pro. Apple told me I would need to replace the logic board, which I refuse to do. Tekserve took a look and said they couldn't help me get the jack out.
My attempts to fix it myself
I read all the tricks online on how to remove the jack and tried a few of them myself. Most of 'em didn't help at all. But using a pair of tweezers I was able to get some grip on the jack, though when I pulled it out the force broke the jack into its separate components, and I only extracted a few pieces from the jack -- one of the metal rings and two of the plastic parts. The tip-end of the jack is still stuck and deeply wedged in the port. All that said, I've given up on manually removing the jack from the outside.
Proposal from a local repair shop
I brought the computer to a local repair shop. (A few months ago this same shop had repaired the wiring in the speaker cable -- the same one that's jack is now stuck in my macbook pro.) The guy there said he thinks if he removed the logic board he could potentially push the jack out of the port from the inside. If not, he said he could try removing the headphone jack entirely. He's willing to do to the work for free since the jack itself came from his shop.
Now, I'm fine if the work results in the headphone jack being unusable. The goal would be to convince the computer that headphones are no longer in the jack, so I could use the internal speakers again. (I can always buy a usb headphone jack.)
My questions
My question is, with this model of Macbook is it possible to remove the logic board AND get access to push the jack out of the port from the inside? Or, if that's not feasible, is it actually possible to remove the headphone jack entirely AND not do damage to the rest of the logic board? 'Cause neither Apple nor Tekserve mentioned this, and I haven't found anything along these lines in my online research.
I'm pretty desperate here but I also don't want to risk doing more damage to the computer.
Two photos here:
- the jack stuck in the port
- the logic board - the headphone port is where the light brown rectangle is
Bu iyi bir soru mu?
