Ana içeriğe geç
Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
592 Soru Tümünü görüntüle
Need help identifying component.
Hi, i have recently got hold of a late 2011 Macbook Pro but id doesn't appear to turn on. I have found on the board that a component was damaged. Can anyone please identify the circled component?
Thanks in advance.
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sam Taylor, that is reference designator C6603 which is a 100UF 6.3 V 20% Tantalum capacitor in a AL1 case. this capacitor is part of your audio speaker amp circuity, should not have anything to do with starting up
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
disconnect the top case ribbon cable and the battery, connect the charger to the MBP and check if you get 3.42 volts on one of the two power pads. Do you have a steady green light on the magsafe light ?
tarafından
Fantastic thank you very much :)
tarafından
Yorum Ekle
Yanıtını ekle
Sam Taylor sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 82
