Ana içeriğe geç
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
306 Soru Tümünü görüntüle
Why won't my controllers connect?
I have an Xbox 360 S, and the controllers will not sync with it. I've tried everything I could find online, and even replaced the rf modulator. I tried plugging them in with a wireless controller with a charging usb cord, and that didn't work either. Any help would be greatly appreciated.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Do you have any wireless routers, microwaves or metallic objects positioned anywhere near your console? These can disrupt the signal or wireless controllers. As far as plugging it in to play that only works if you use the play and charge kit. Which asks you to connect the battery pack to the USB cable and that to the console. If after all of this still nothing is working your USB ports may be damaged, or the console itself may be damaged. If you can also try using friends controllers to test whether or not it is the controller that is malfunctioning.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Pat sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 1,198
