Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
529 Soru Tümünü görüntüle
Replace Early 2011 Logic Board with Late 2011 LB?
The GPU of my MacBook Pro (17-inch, Early 2011) crashed, leaving the it unable to boot after hanging on a screen with green vertical stripes.
Apparently a lot of MacBooks from 2011 share suffer from this (https://www.change.org/p/timothy-d-cook-...)
I was wondering, since the entire logic board needs to be replaced, if it can be replaced with the logic board of the Late 2011 series.
It's only a minor upgrade of the CPU and GPU:
Early 2011 Late 2011
Processor Number: I7-2720QM I7-2760QM
Processor Speed: 2.2 GHz 2.4 GHz
Video System: Radeon HD 6750M Radeon HD 6770M
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
'"Apparently it should be possible, sorry for reposting.'"
Which MacBook Logic board should I purchase?
"The boards are the same within model years... including early to late '11 so if you can find the faster (2.2GHz-2.5GHz) board it would work."
http://www.everymac.com/systems/apple/ma...
Bu yanıt yardımcı oldu mu?
Puan 3
Yorumlar:
Olivier - Give your self credit here you figured it out ;-} Mark the question resolved so you get the points.
tarafından
Yorum Ekle
Yanıtını ekle
Olivier sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 5
Son 30 Gün: 21
Her zaman: 646
