Ana içeriğe geç
29875GE1 model numarasıyla tanımlanan GE Digital Messaging System
Why doesn't the remote control work
Device Won't Respond to Remote Control Commands
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Make sure you are using a touch tone (or push button) phone. When you are setting up the remote commands, make sure you are using the correct security code. Also make sure that the unit didn't hang up while you were attempting to enter your remote commands.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Make sure your components are turned on and yourTV is set to display the appropriate video source.
You must put the remote in the correct mode bypressing the corresponding component key (TV,DVD, VCR, AUX, SAT·CBL) so the remote knowswhich component you want to operate.
Remove any obstacles between the remote and thecomponent. Make sure to aim the remote at the IRsensor on the component.
Make sure the batteries are fresh and are properlyinstalled. Replace the batteries with two new AAAbatteries, if necessary. Reprogramming may berequired.
Reset the remote details are here. , reinstall the batteries,and press the ON·OFF key. If the indicatorlight lights up, reprogram the remote and try again.If it doesn’t light up, replace the batteries with newones
Puan 0
Yorum Ekle
Yanıtını ekle
Antonio Monteiro sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 34
Her zaman: 556
