iPhone bootlooping when plugged in? (No Jailbreak)
I have an iPhone 4S that my friend gave me. It was dead when I got it, so when I got the chance I plugged it in to charge. It showed the usual battery indicator (it was red indicating it was drained) a few minutes later it booted up and showed the Apple logo and for a few seconds it stayed like that. Then it vibrated, showed the spinner and preceded to boot and shutdown, again and again. iTunes could detect it, but only for a few seconds, (as it only stayed on momentarily). I did try putting it in DFU mode by holding the Home button, Home + Power button, and other various button combinations, but no luck.
I suspect maybe it's a power issue? Maybe the battery is reaching enough power to boot up, but not enough to stay on and it's shutting down when it tries to? Maybe the battery is dead and needs to be replaced? These are a few of my theories and I'd like to see what anyone else thinks and what I should do at this point.
It is out of warranty, so user repair isn't out of the question. I'm just wondering If I should replace the battery, the charging port, or maybe just get a different charger?
What do you think is wrong and what sowld I do next?
Thanks!
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I think you should first try another (new) battery, because it might be faulty.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorumlar:
Ok, thanks for the tip, I probably will (already ordered tools) I'll try and disconnect/reconnect it first. If no luck then I'll get a new battery
tarafından
Yorum Ekle
Yanıtını ekle
Gabriel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 83
