Ana içeriğe geç
2.26 or 2.4 GHz / White plastic unibody enclosure
645 Soru Tümünü görüntüle
Soru Kapandı
There's a connector on my logic board that's unconnected
I opened the bottom case to check for a certain issue and I noticed that this connector is not connected.
My audio doesn't work and I have some issues with charging and start up sometimes. Could this be related and how do I fix it?
Bu iyi bir soru mu?
Puan 0
1 Yorum
Based on your EMC, your computer is a 2.26 GHz Core 2 Duo (P7550)
Intro Date: October 20, 2009 Disc Date: May 18, 2010
Order No: MC207LL/A Model No: A1342 (EMC 2350*)
Subfamily: Late 2009 Model ID: MacBook6,1
Std RAM: 2 GB Std VRAM: 256 MB
Std Storage: 250 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Vanessa, that is your left speaker connector. Looks like it is totally off the board. You will have to resolder it. From your picture it appears that the pads are okay so a simple touch-up with a soldering iron should be sufficient. It is most likely responsible for your audio issues, but not your start up, unless the loose connector would shorten something else out. Resolder it and the re-evaluate.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
Thank you. I'll do that. sometimes when I power up the computer on the fan will turn on as if its starting up but the screen will remain black. I usually have to wait several hours bbefore it will start normal again.
tarafından
In that case you may want to connect an external monitor and see if you can see on that one. It is possible that you may have a bad inverter circuit or LED driver. repair one thing first then go to the next issue
tarafından
Ok. I will try that after I fix the connector. Thank you for all your help.
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 108
