Ana içeriğe geç
MiP robotu, Ağustos 2014'te piyasaya sürüldü. MiP, çocuklar için tasarlanmış etkileşimli bir robot oyuncaktır. Robot, el sensörü teknolojisinin yanı sıra MiP'in sürülmesine, dans etmesine ve oyun oynamasına olanak tanıyan indirilebilir bir uygulama aracılığıyla yanıt verir.
MIP bluetooth won't discover
Trying to use bluetooth with my iphone 6 and it never FINDS the MIP---just says discovering over and over...Thoughts?
Bu iyi bir soru mu?
Puan 12
7 Yorum
How to pair it and is deos'nt register
tarafından Paylaş
Having same issue. Tried replacing batteries, uninstalling/reinstalling app. No success. Entered a ticket on WowWee's website, but no answer yet. Will post when they do. Please update if you find a resolution.
tarafından Paylaş
We had the same problem. We ended up exchanging it for a new one. We knew something was not right when it wouldn't connect to any devices including an iPhone 6. As soon as we turned on the new one - it connected to our son's nexus 7. Looks like the Bluetooth was broken in the original mip.
tarafından Paylaş
Please can someone help me! I need the password for the bluetooth when trying to connect? Any ideas as to what it could be and where i could find it
Thanks
tarafından Paylaş
does bluetooth on? if not do this scroll down
tarafından Paylaş
2 tane daha yorum göster
Yorum Ekle
8 Cevap
Filtre ölçütü:
Seçilen Çözüm
Try switching Bluetooth on or off in the Settings and try pressing the refresh button in the top right. As mooka1 said, try tapping on the auto-connect screen.
Bu yanıt yardımcı oldu mu?
Puan 4
1 Yorum:
I have an LG k10 and I am haveing the same pobelm
tarafından Paylaş
Yorum Ekle
if its stuck not the search for mip screen (has the mips jumping up and down on it) tap the screen and you should go through to another screen that allows u to pick a mip.
hope this helps.
Puan 3
Yorum Ekle
The MIP robot is no longer discovered with the Android 8.0 (Oreo) update (bluetooth issue). Already reported to Google.
Puan 2
2 Yorum:
This is correct I have android 8.0 and I was able to connect the mip to the app, but after I had to change the batteries the mip isnt showing up on my phone again. Very frustrating.
tarafından Paylaş
If your mip doesnt turn on with new batteries then there might be a loose wire. I had TO takes the screws out of his back and mess with the wires. There should be a black and red wire (thicker than the other wires) have masking tape on the end of the wires. Tape the wires back to there circuit board and it should turn on
tarafından Paylaş
Yorum Ekle
What about pie? Not working on Samsung s9 plus
Puan 2
Yorum Ekle
I Can't connect my Mip to my phone. It says I need a passkey but it never said that before. Earlier it connected flawlesly. Please help me find a fix.
Puan 2
1 Yorum:
Yeah me too can someone help . What is the pin?
tarafından Paylaş
Yorum Ekle
Try switching Bluetooth off and then on a couple of times. If not the try charging the MIP.
Puan 1
Yorum Ekle
It worked just fine on android 5 untill i put new batteries into mip then its not showing on the app it shows the mip in the Bluetooth menu but it needs a
Puan 1
Yorum Ekle
I try connecting to Bluetooth and it asks for a pin
Puan 1
Yorum Ekle
Yanıtını ekle
publicinfo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 52
Her zaman: 33,033
