Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
337 Soru Tümünü görüntüle
Temperature of mac vs fan rpm
The fan on my mid 2014 macbook pro retina always seems to be running at around 1300 or so rpm. However, it doesn't seem to go higher even when the system temperature increases.
For example it was once operating at around 71c with only around 1295-1306rpm.
Is this normal operation?
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorumlar:
You raise a good question here on what is the max RPM this systems fan runs upto.
tarafından
Yorum Ekle
Nintendo Switch Setleri
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The fans can run at 2,200 RMP or more, but it's best not to fool with them manually if at all possible.
If you want to investigate the state of your hardware, connect the MacBook Pro to a charger and use Apple Hardware Test. In case of heat issues, or to generate more heat run the test 2 or 3x in succession.
After starting into Apple Hardware Test, choose your language, mark the option to run an extended test and start the test. If at the end of the test you see an error, run it down.
If this answer is acceptable please remember to return and mark it accepted.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorumlar:
Agreed! + Using software to over-ride the fan/s only shortens the life of your system. What is important is using the correct hardware and if needed adapter cables so the built-in temperature management system is able to effectively manage the heat generation in real time.
tarafından
Yorum Ekle
Yanıtını ekle
Will sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 60
Her zaman: 3,876
