I'd also look at the drivers & firmware from other hardware.
I think we can safely asume
1) >=2 sets of firmware installed on the Ntrig. Base firmware we can see on the chip as V1.1 v 1 +++
2) The installed underlying firmware matches 'a' basic/user updatable firmware
3) That the factory didnt put these in production for the !&&* of it. And as such there may be a windows device/ manufacturer that has the correct user installeable firmware/ drivers. Either for W7 or W8 or W8.1
To me trying ubuntu would be for investigative purposes only.
I think it may be worth while trying to find other devices that use the Ntrigg duo sence.
The list can easily be obtained by looking at the available drivers/firmware on the Ntrigg website.
I would start with drivers for machines that were pre W8.
I also found this list of drivers whilst looking for drivers for the Sony Vaio Duo 11
http://www.driversdownloader.com/drivers...
Good luck.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
0
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
11 Yorum
I'm in the same boat... Been looking for v1.1 for more than 2 months now... Hopefully someone can point us in the right direction.
alexp31 tarafından
Same problem, Did you figured out where to buy V1.1? Thanks
Kiavash tarafından
I'm also looking, any ideas?
smarttechiowa tarafından
there isn't one available. Also if it was it would cost a stupidly large amount ($350+), as far as I know the official microsoft replacement cost is only $300 (and you get a mint condition unit!) So just pay microsoft to replace it and be done with it.
z0bug33 tarafından
I would agree if in waranty and it has not been tampered with get MS to replace the unit.
NOTE: V1.1 is available although they as marked 1 1 not 1.1 like the original.
So far I have received 2 both from different suppliers in china. 1 had part of digitizer that didnt work. the other, the back light had failed. Really appauling. Then i am still lumbered with Duty and vat which can not be reclaimed easily. Beware of HK or Chinese sellers.
champagnecharly tarafından
6 tane daha yorum göster
