Ana içeriğe geç
Remove CD from iBook that won't power up?
How can I remove a CD from an iBook that does not power up?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Remove the optical drive and open it up. Here's how to do it:
iBook G4 12" 1.33 GHz Optical Drive Replacement
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
No, tape did not work. I tore the iPod apart and got the disc out.
tarafından
Yorum Ekle
Try holding the trackpad down at power on - the disk should eject.
If that fails try the double sticky tape method:
  1. Get an old CD/DVD and some thin double sticky tape (like scotch tape ~3/4in wide).
  2. Put a couple of strips close together on one edge of the CD/DVD,
  3. Firmly hang on to the CD/DVD and angling the disk put it part way into the slot TAPE SIDE DOWN.
  4. Rotate the disk flat. (You want to try to snag the disc with the tape, so that you can pull it out)
If that doesn't work time for mayer's solution.
If this answer is acceptable please remember to return and mark it.
Puan 1
Yorum Ekle
Yanıtını ekle
Edward sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 317
