Ana içeriğe geç
Support and repair information for laptops made by Samsung.
Samsung ATIV book 9 lite micro hdmi port problem
When I put the cable in the lcd tv and plug the micro hdmi at my ativ book 9 lite nothing happens the notebook does not recognize my external tv or projetor via micro hdmi. How can I solve this? Is there any micro hdmi drivet needed to be installed or does the micro hdmi port needs to be activated somehow? Please help me
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
Yorum Ekle
6 Cevap
Filtre ölçütü:
I have this same problem. I found a similar problem on a Lenovo Yoga board and they solved it by shaving part of of the plastic off of the plug, about a millimeter. It is not a 100% fix for the Samsung because you still have to angle the plug up to make the connection work and it is loose, but it does work.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Hello,
i have a problem with connecting my samsung ativ notebook to my external monitor with HDMI (micro).
This problem has occured since a week. I bought the laptop with windows 8, but currently using windows 10 (since 6 months).
It seems to be a driver issue... with the Radeon HD 8250 AMD.
Device manager says that there is a problem with graphic drivers.....Microsoft Basic Display Adapter (No ACPI support). I tried to delete it, but after that it still did not work.
Does anyone have any idea?
Please help me!
Puan 0
Yorum Ekle
Not sure if this helps but I have an ATIV book 9 lite with win 10 and the hdmi works fine
I did use drivethelife to update all of my drivers after installing win 10, don't know if that made any difference
Puan 0
Yorum Ekle
Unplug the HDMI cable - Go to "Device Manager" - "Dispaly Adapters" - "Intel Graphics" - Click the Driver option - Roll Back Driver (to whatever previous version) - then Update Driver again - Restart Computer and plug the HDMI back to test if it works.
Do this couple of times if it does not work at the first trial.
Puan 0
Yorum Ekle
I have same problem with my N905s3g , I use the micro hdmi to vga , the laptop recognize the external monitor and works beautiful for couple of minutes. then the monitor goes to black, I have to unplug the cable , and plug the cable again to get monitor ,but it lost again after couple of minites
Puan 0
Yorum Ekle
Someone else having a loose microHDMI and charge connector? Happened on all our Samsung laptops, getting glitched problems.
Puan 0
1 Yorum:
Yes I have. They wear out and the micro HD​mi is of poor quality. On my 4th adapter. Im going to buy a good quality adapter but micro to hdmi is hard to find
tarafından
Yorum Ekle
Yanıtını ekle
Meg sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 6,263
