Ana içeriğe geç
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
310 Soru Tümünü görüntüle
Soru Kapandı
thermal señsor cable incompatable
I bought a seagate SSHD for my iMac. Installation was pretty easy until the last steep. The sensor cable is a square, 2 hole female plug but the seagate has a rectangular receptor with 4 pins. No way to connect the two. Is there an adaptor or should I return this SSHD for something else?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Don't panic!
Ideally, you should use the same manufacture's drive your system has WD for a WD, Seagate for a Seagate etc...
If you want to stick with the Seagate drive you'll need to swap out the sensor cable harness. In this case you'll need the Apple P/N: 922-9216.
Here's one source: Intel iMac 21.5" Hard Drive Temp Sensor
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 142
