Change memory flash 16 Gb for 32 Gb
I have an iPhone 3GS 32 Gb and iPhone 4 16 Gb, it's possible change the flash memory 16 Gb in iPhone 4 for 32 Gb from my iPhone 3GS???
Thanks!!!
Bu iyi bir soru mu?
Thanks!!!
Bu iyi bir soru mu?
In a word, no. The pinout is the same, but the solder points are inaccessible. If you have an automated solder rework station, something like that found here: http://www.apolloseiko.com/ then yes, you can do it.
In all likelihood, all you will accomplish is breaking two phones to try to save $100
Bu yanıt yardımcı oldu mu?
No. The NAND Flash are hardwired onto the logic board. Unless you have access to reflow equipment and resolder IC's there is no way you can get it accomplished.
Hi. How do you flash IOS in a new nand flash changed chip ?
This is not practical as the memory is encrypted, unique to each phone.
We cant change Iphone 3GS memory to Iphone 4 but We can change Iphone 4 16Gb to 32Gb
If you want to change memory you want to get Iphone 4 32Gb Toshiba Flash memory chip
If you Want to change memory you may contect me- It's possible...
Name- Neshanth
E-Mail - TNeshanth@gmail.com
Contect No-0094 766147097
Yes, you can use any storage size iPhone 3GS screen to fix any iPhone 3GS. This is true of all models. The storage capacity of the phone has no effect on screen compatibility. Make sure everything else is the same, but you don't need to sweat the storage.
First you have to remember with Apple devices like iPhones the the processor and flash memory are paired. However their are you was around it 1st take a phone were the processor and flash memory work ie the logic board had otherwise been damaged 2nd if you know all the spec of the processor their are some company's that will program the flash memory with the processor information then the processor and memory are paired. You are limited by the capility ie if your devices max size is 128gb then that is the max memory size you can install. You can buy the machine that will program the flash memory but bit expensive.
This is a project that should only be done good at taking the device apart and putting back together again and the use of heat gun to remove the heat shields and chips.
In the end is it worth it
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 15,029
3 Yorum
But it's possible? The chip have the same pins??
Emilio Alcaraz tarafından
I have an iPhone 4 32 Gb. it's possible change the flash memory 16 Gb in iPhone 4 to 32 Gb.
Thanks!!!
geeharders tarafından
i wanna kno something just like this question, I have 2 iphones 6 butone is64 and one is 16 . the64 I ran over but it still worksmy screen is just screwed, can I take the 64 out my old phone and put it in my new one ?
banks loc tarafından
