Ana içeriğe geç
Toshiba Satellite L300, Toshiba tarafından tasarlanıp satılan ve Windows Vista'nın bir sürümüyle gelen bir dizüstü bilgisayardır. 2009 yılının Mayıs-Haziran ayları civarında satılmışlardır ve ücretsiz Windows 7 yükseltmesi için uygun olmasalar da, zaman geçmiş ve yükseltmeler artık talep edilemez durumdadır. Vista'nın kaynak tüketen yapısı nedeniyle, yükseltme olmadan bile Windows 7 Home Premium'u iyi bir şekilde çalıştırırlar. Toshiba Satellite L300-04P (PSLB8C-04P01X) olarak da bilinir.
Power supply won't connect
Hi
The post inside my laptop that the power cord goes onto doesn't seem to make a connection anymore. If you put something in there you can see that the post moves around pretty freely so it must have either broken or come loose. Is there a way for me to fix this or do I need to find a repair centre?
Thanks!!
Bu iyi bir soru mu?
Puan 3
1 Yorum
I have the qosmio x75 and it stopped all together, no charge light, no light, and no screen, any suggestions on what to do to fix. Please
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi, This seems to be a common problem with the Toshiba. Here is a link to a successful mod to repair the problem. Please pay special attention to the cautions the modder makes and read all the way through before deciding to do this. Good luck. Ralph
http://www.insidemylaptop.com/repair-dam...
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
+ for doing the work others didn't
tarafından
Yorum Ekle
After you take apart the laptop, if it is just a loose connector, you should be able to just solder it back in place.
Puan 0
Yorum Ekle
I have this happening to my Toshiba again - third time since I began using it in December 09. Going to try the workaround to see if I can avoid buying yet ANOTHER power supply. Thanks!
Puan 0
Yorum Ekle
It says something like my adapter broke
Puan 0
Yorum Ekle
Using Toshiba Satellite Radius 14 and worst laptop ever. Power cord doesn't keep connection after 1 year and on their website they want $55! The screen broke on one side at 7 months when your supposed to be able to make a tablet, never again.
Puan 0
Yorum Ekle
Yanıtını ekle
nicksmom1962 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 31
Her zaman: 32,379
