Solution 1: Check for conditions that might prevent charging
Is the electrical outlet you’re using to charge your Surface working properly?
Try plugging something else into the outlet and see if it works.
Are conditions right for recharging?
It’s best to charge your battery near room temperature. Surface is designed to work between 32° and 95°Fahrenheit (0° and 35° Celsius).
If these things are OK, continue with Solution 2.
Solution 2: Disconnect cords, remove accessories, and check connections
Step 1: Unplug the Surface power cord from the electrical outlet. If you have any of the following, remove or disconnect them from Surface:
Power supply
Surface Cover
microSD card
USB devices such as printers, keyboards, or mice
Video or audio cables or adapters
Step 2: Check the magnetic connectors on the power supply's connector tip and on the charging port (on the side of Surface itself). With the power cord unplugged from the outlet, clean the magnets on the Surface connector tip and the charging port with a soft cloth and a small amount of rubbing alcohol.
Surface RT charging port and connector
Step 3: Reconnect the power supply to Surface and plug the power supply into a working electrical outlet.
Charging connector on Surface RT
Charging connector on Surface 2
Step 4: Look at the connector to see if the light is on.
If the light does not turn on, your power supply may need to be replaced.
If the light does turn on, try to turn on Surface.
Step 5:
Press and release the power button on your Surface. The Surface logo should display within a few seconds.
If your Surface turns on, the battery on your Surface is likely still very low. You will need to let it continue to charge for a while. When the battery has a 40 percent charge, install the latest updates to help prevent the problem from occurring again. For more info, see Install Surface and Windows updates.
If your Surface still won’t turn on, try Solution 3.
Solution 3: Force restart
Step 1: Press and release the power button on your Surface, and allow up to 30 seconds for the Surface logo to appear.
If your Surface still won’t turn on, continue to Step 2.
Step 2: Press and hold the power button on your Surface for 30 seconds. The screen will flash during this process, but continue to hold down the power button for the full 30 seconds.
Step 3: Press and release the power button on your Surface to turn it back on.
If your Surface turns on, the battery on your Surface is likely still very low. Let it continue to charge for a while. When the battery has a 40 percent charge, install the latest updates to help prevent the problem from occurring again
Please accept answer if this solves your issue.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
2
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
14 Yorum
Did you just purchase this or have you had it for a while? Did the battery totally die on this, before you attached the charger? Have you checked for continuity between the pads on the new charger port and where the traces lead? Checked for proper polarity on the battery?
ABCellars tarafından
u can't disconnect the battery on a surface there's no battery to remove it is sealed up in the casing unless u break the seal around the case and then u scrue the hole thing up and might as well use it as a paper weight
Virginia Layman tarafından
Me too. I got a replacement and that doesn't work either. I need it for printer, external hard drive, and CD/DVD player. Any suggestions?
Diana Morcom tarafından
Your comment is awaiting moderation
My SP3 is “dead” , when the power is plugged in , the white power-cord light is on, but no heat is observed whether on the supply or the SP3(no power is drawn).
Have tried any trick of "awaken it" from a possible sleep state by press&hold power and power+volume up for some time, no result.
One of two:
1.The battery is dead,
2.the charging circuitry inside the pro3 is bad.
Are there any way to find it out ?
by the way , the powersupply is almost “brand new” , and the extra usb output located on the supply is working well.
Possible fix: Buy an powersupply that uses the docking type plug underneath, hoping that this other connector has its own charging circutry.
rolfeilert1970 tarafından
Earlier today I had been using my Surface Pro 4 and the charger was working fine. I had the charger out and it had gotten to 10% so I went to plug in the charger and it did not work. I've been trying to find a solution for 4 hours and nothing is working. It's completely dead and when I do the volume up button + power button it just shows low battery. The light on the charger is not working and I'm so confused.
ljhx x tarafından
9 tane daha yorum göster
