Ana içeriğe geç
Sony Computer Entertainment tarafından üretilmiş bir oyun konsolu. PS4 olarak da bilinir. İlk olarak 20 Şubat 2013'de duyurulmuş ve 15 Kasım 2013'te satışa sunulmuştur.
1695 Soru Tümünü görüntüle
Soru Kapandı
Broke the 5 wire conector from psu in the motherboard
Hi, while trying to take out the power supply, accidentally took the entire conector (5 black wires)that is in the motherboard(out of it). Now i'm afraid that i won't be able to solder it. Is a simple solder or i'm screwed?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
This all depends on whether you tore off the pads on the motherboard or not. You should be able to tell by cleaning them good. If they still have solder on them and they are not loose then they are probable fine. You can also look on the connector to see if any solder pads are stuck to the pins.
If they have not been torn off then it's just a matter of soldering the pins back on which is fairly simple. If they have been torn off then you need to solder a small wire from the connector pin to the copper trace on the motherboard that corresponds to that pin.
I hope this helps.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 130
