Ana içeriğe geç
The NutriBullet by the makers of Magic Bullet is a personal blender that is self-contained and simple to use. It includes an electric blender base with a number of attachments for the user and offers a healthy alternative to blending food by breaking down ingredients in their most nutritious states.
Why don't the blades spin and/or make a noise?
The blades on the NutriBullet refuse to spin and there is no sound coming from the power base.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
2 Yorum
What have you checked? Could be the switch, the thermal fuse or the motor.
tarafından
Hi I want to know on my nutribullet on the motor it makes funny noise and a weird burning smell then I found out there is like black powder like stuff around the motor so I cleaned it but still the same what would be the solution ?
tarafından
Yorum Ekle
6 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hello,
It sounds like your NutriBullet isn't turning on at all. This could be caused by a number of problems.
If your NutriBullet blender will not turn on and shows no signs of life, use the Magic Bullet NutriBullet Won’t Turn On problem page for possible problems and solutions.
If your NutriBullet blender is making noise but the blades aren’t spinning, see the NutriBullet Blades Will Not Turn problem page for possible problems and solutions.
If your NutriBullet blender’s blades no longer blend food, see the NutriBullet Blades Won’t Cut or Blend Food problem page for possible problems and solutions.
First, check that you are plugged into a working power outlet. Try plugging in another device and seeing if that device works with that outlet. Once you make sure the outlet is working, the next biggest culprit is a stuck activator button. They can get stuck if sticky juice gets on them and then hardens. You can check the white activator buttons on your device by looking at them and pressing on them with a flathead screwdriver. Finally, if the activators are working, then the motor might need to be replaced. If your NutriBullet is still on warranty, then contact magic bullet about a replacement.
Hopefully, this was helpful! If you like my answer, be sure to shoot me an upvote!
Bu yanıt yardımcı oldu mu?
Puan 3
4 Yorum:
Whoa, hang on there future writer of America. " Finally, if the activators are working, then the motor might need to be replaced. " I think you should suggest a few more things before saying buy a new motor.How about the wiring? Check the wire nut connections on the AC cable to make sure they are still properly installed and that the wire is still connected. How about the switches? There are two switches in series, if one has failed, your Nutribullet will not start. What about the checking the thermal fuse? If it has failed (a $2 USD part) your Nutribullet again will not start. I suggest you tear it apart, use a multimeter to check the switches and the fuse,then determine what you need to purchase. Sorry Nicholas Hardy, no upvote until all other avenues have been explored.
tarafından
thanks for the detailed steps! Mine also stopped working last night when I tried to grind some hard food. Any tips on how to test the switches and thermal fuse? I have a multimeter, although I only know how to measure voltage and connectivity with it. thank you.
tarafından
Had the same problem with my unit. Dissambled it and found two wires coming from each switch that were frayed, one was actually not frayed but bent that i could feel it was broke inside the insulation. Fixed them both by splicing and using some rubber shrink tubing. Also noted this unit uses some cheap plastic support for the rubber gommets used as shock absorbers. one broke and the motor shook more than it should of. Crazy glue helped set it back in place for now. not sure how long that will last. Overall the machine works like new. cost to fix less than a buck.
tarafından
There are three white rubber bushings located on the inside of the base. The cup and blade when pushed down come into contact with them. I have one missing, could that stop the device from operating?
tarafından
Yorum Ekle
I tried the wall outlet with another appliance and it worked. Then I closely examined the main base and noticed that two of the white tabs on the rim were stuck and not moving down when pushed so I used a small screw driver and tapped lightly and the tabs moved. I plugged in and the base worked fine. This unit was almost new ... Only used a few times and very clean. Some liquid must have sealed the tabs.
Puan 0
Yorum Ekle
I got my nutribullet 2 yrs back. Everything was going great with it. But last couple of weeks, I am hearing really loud frictional noise whenever I try to use it. What are the probable cause ?
Puan 0
Yorum Ekle
Don't do what I did.
Before you try anything... check to make sure all 3 tabs are on your cup.
I broke down the whole unit. It looked good. I put it back together only to find a tab missing from the plastic cup.
Thankfully, I had another cup.
Puan 0
Yorum Ekle
Hi I want to know on my nutribullet on the motor it makes funny noise and a weird burning smell then I found out there is like black powder like stuff around the motor or armatuer. When I further investigated, the brushes which ought to make contact with the armatuer were breaking apart when you touch it. The spring that makes up the brush was not that springy. I think heat over time is result of that. Therefore, I think I need new brushes for the bullet. Where can I get them to purchase?
Puan 0
Yorum Ekle
You may contact Nutribullet Customer Service Department at 855-346-8874 for assistance on using the product or warranty service. (Mon– Sun, 9am–8pm EST). You will be required to provide the barcode/serial number located underneath your Power Base.
Puan -2
Yorum Ekle
Yanıtını ekle
Angela Wong sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 65
Her zaman: 19,102
