Ana içeriğe geç
The Asus X200MA is a portable touchscreen laptop with an 11.6" display. This device was manufactured in 2014 and is also identified as Asus X200MA-RCLT07.
Why won't my laptop charge properly?
I charge my laptop for hours and it shows that the battery is drained or isn't charging.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 10
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Vanessa,
First, make sure the charger is completely plugged in. If it is, it may the outlet that isn't receiving power. You can test that by plugging something else into it.
If that still isn't working, you may have to replace the battery. The same thing happened to my computer. Replacing the battery fixed the issue.
I hope this helps!
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
I just replaced my battery. It worked well for nearly a month but now I'm having the same problem. It's plugged in but the battery is not accepting the charge.
tarafından
Yorum Ekle
I have the same problem. I just use my laptop 9 months. but now it's dont want charging (just keep 0%) and the battery indicator flashes. Do replace a new battery can be more durable ? Then how the technic of using the batteries so it's can be durable?
Puan 0
Yorum Ekle
My ASUS R510C Notebook PC does not power up if I disconnect it from my household electrical receptacle. Do I need a new battery
Puan 0
Yorum Ekle
Yanıtını ekle
Vanessa Garcia sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 10
Her zaman: 2,050
