Ana içeriğe geç
Updated in March 2008 with 802.11n Wi-Fi support, the AirPort Express A1264 is a compact and portable wireless network device.
14 Soru Tümünü görüntüle
Why my apple airport express is blinking orange
since light my apple airport express is blinking orange. i don't know what could be the reason and suddenley there is no light . help
Bu iyi bir soru mu?
Puan 3
1 Yorum
i did some steps like i reset the airport and also try to re-setup the everything it just did not work i don't see any hardware problems . i think its best to contact apple http://goo.gl/Y1fN24 . lets see if that works
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
Have you tried accessing it using the AirPort utility program?
A orange LED implies there is a configuration error. This can happen when you have alter the connection or the ISP has altered something on their side of your connection.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
A persistent, flashing amber light indicates that any of the several potential conditions may require your attention:
• The base station has not yet been configured because it is new, or the reset switch has been set.
• You have selected a security configuration that is not recommended.
• A new firmware update is available for the base station.
• One of several other conditions, such as a disconnected Ethernet cable or invalid IP address has been detected.
ref: AirPort base stations: About AirPort base station status lights (LED)
To find out why your base station's status LED is flashing amber:
• Open AirPort Utility
• Click on the AirPort base station
• Look for a Status setting in the small window that appears. Note: Status only appears if there is an issue or notification.
Click on the small amber dot there and another window will open to explain what the "issue" might be.
Puan 2
Yorum Ekle
reset the router and reconfigure the router settings and make sure you are getting internet with your isp .
Puan 0
Yorum Ekle
What if the Airport Express won’t show up in Airport Utility?
Puan 0
Yorum Ekle
@Dan Cronin
If the base station does not show up in the AirPort Utility, give the following a try:
  1. Temporarily connect your Mac or PC directly to the Express by Ethernet, and then, try using the AirPort Utility again.
  2. Try using an iPhone or iPad instead. These tend to work “better” in finding a base station. Just use the AirPort Utility app.
  3. Make sure that your Mac or PC is configured for a minimum of IPv6 Link-local only. The AirPort Utility relies on both Bonjour and IPv6 to discover a base station.
  4. Try a “factory default” reset on the base station.
Puan 0
Yorum Ekle
Yanıtını ekle
dangcynthia sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 118
Son 30 gün: 527
Her zaman: 82,606
