Cost of the retina display and backcase
Dear sir/madam,
What will the cost be of the retina display for the imac retina 5k. And what will be the cost of the backcase?
Thank you in advance for your reply.
Kind regards,
I. Johnson
Bu iyi bir soru mu?
3 Yorum
Please tell us what the problem is. These parts are very hard to find as the machine is under warranty.
mayer tarafından
The left upper corner has been damaged a little. Although the iMac is working, I find the damage disturbing and want it to fix. I would like to know what the cost will be of the replacement parts (aluminum back and retina display).
Thank you in advance.
iris tarafından
Can you tell us what happened. How about a few pictures so we can see. Maybe we can figure out something to mask it. If you got the system this way I would recommend going back to the seller for a replacement. The cost of swapping out the case and the display will be very close, if not more than buying a new system (parts & labor). Frankly, I'm with Mayer here, you may not be able to get the parts for sometime as the system is so new.
Dan tarafından
