2.26 or 2.4 GHz / White plastic unibody enclosure
674 Soru Tümünü görüntüle
How do I reconnect speaker wires to logic board?
Unable to find original holes on logic board. What is the best way to reconnect speaker wire to logic board?
Update
Yes. I believe you are correct and that connector was removed from the Logic Board.
Is there any way to correct this?
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorumlar:
Pictures could help here so we can see the damage
tarafından
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sounds like you pulled off the connector on the logic board. Can you take a couple of good pictures so we can see what happened. We need the cable end and the location the speaker cable would connect on the logic board. Review this picture as reference: Speaker connection.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorumlar:
I have a picture but don't see an Attach File button.
tarafından
It's a bit tricky, here's the steps: Technique: Adding images to an existing question
tarafından
Yorum Ekle
Yanıtını ekle
w7744 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 2
Her zaman: 77
