Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4988 Soru Tümünü görüntüle
Back Camera not working after screen replacement?
Hello,
So I had cracked my iPhone 6 screen and, after replacing the screen, my front camera is working as it normally should but when I switch to the rear camera, the camera app freezes. Also, the flashlight does not work. Any ideas how working on the front of the phone could have caused this or how to go about fixing this issue? I have tried restarting the phone, and updating the iOS to the latest version.
Bu iyi bir soru mu?
Puan 32
Yorum Ekle
12 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hey, I've not long had the same issue, luckily I had a spare iPhone 6 on hand and swapped the rear cameras, no idea how I broke it as I never touched it.
I've been doing phone repairs for years as well.
And it's weird that the back camera causes the back flash not to work, considering they are now separate units and not on the rear camera itself, as soon as I replaced rear camera, both rear camera and flashlight worked!
Bu yanıt yardımcı oldu mu?
Puan 4
7 Yorum:
Is it possible to order the original rear camera, my case happens to be very similar to yours. Or do you know if jumping the IC creates any further slow or permanent damages?
tarafından
Santosh: The component is a voltage-regulator that deliver 2,85V to the cameras. If you jump this pins, you'll give 4,6V to the cameras. So this may damage other components.
tarafından
I can see maybe where I went wrong myself, as I used the gTool to reshape the corner where the back camera was, and I hadn't unplugged the battery, so maybe caused some sort of shortage?
Like I said, I replaced the back camera and all was fine.
It's quite unfortunate that a few people seem to be having this issue without really touching the back camera, I haven't really seen it in any of the other iPhones except the latest.
If replacing the front and back camera doesn't work, chances are it is logic board damage somewhere on the board.
tarafından
I have the same issue with my 4S. Both cameras don't work after replacing of screen. What to do??? :((
tarafından
Is there a simpler way to detect the shorted circuit itself?
tarafından
2 tane daha yorum göster
Yorum Ekle
En Yararlı Yanıt
change camera if not work then make jumper on camera ic
Puan 14
11 Yorum:
This solution worked! I can't thank you enough! A really huge thanks!!
tarafından
I've checked the schematics, and this component is a voltage-regulator that deliver 2,85V to the cameras. If you jump this pins, you'll give 4,6V to the cameras. So this may damage other components. Anyways very helpful. Now I know what to do to fix this. :-) The name of the component is U2301 if other people want to search for places to buy a replacement IC.
tarafından
thank you so so so o much helpfuuuuuul
tarafından
السلام عليكم اخي لدي ابفون 6 الكاميرة مرة تفتفح ومرة ما تفتحوتعمل بلوك مرة تصور ومرة تصور ومرة تجي الشاشة السودء عفهل نفس المشكل وشكرا
tarafından
Hey, how you jump?
Does the battery have to be connect, when u connect the two things with a metal piece.
tarafından
6 tane daha yorum göster
Yorum Ekle
My back camera and flashlight on IPhone 6s+ stop working after I damage flex cable from rare camera and earpiece.I did replace it and everything back to normal.So anyone who have this issues shoul check flex cable and also if you're earpiece is working or not.Seems like back and front camera,flashlight depend on each other,but someone mention it not.So that solution may work for someone :)
Puan 1
3 Yorum:
Some components are shared between the front camera, rear camera and flash, and other are not. So if the other functions is affected depends on the fault.
For example they share a voltage-regulator, if that one is faulty, both the cameras and flash would fail.
tarafından
My ip6s+ front and rear camera both don't work, do you think replacing the cameras will solve the problem?
tarafından
I just replaced my battery and I'm having those issues. When I open my camera the screen is black. I can't switch from rear or front. The Flashlight does not work when I make calls I can't hear anything through the earpiece. Can you help me???
tarafından
Yorum Ekle
You just need to purchase a new camera on Aliexpress or wherever you purchase and replace the old one for the new one. That will make it work. In the future be sure to turn off the iphone and unplug the battery before you replace a screen - that will prevent that from happening ever again.
Puan 0
Yorum Ekle
Maybe the protective plastic over the camera
Puan 0
Yorum Ekle
replacing or just put a jumper, it really works. U2301
Puan 0
4 Yorum:
This component ajust the voltage from 4,6V to 2,85V. If you just make a jumper you'll feed the cameras with 4,6V which can do damage to other components. I'll recommend to replace the component with a new one.
tarafından
How u jump it?
Just connect it with metal, w battery on?
tarafından
ezzat: Just solder the points together with tin. No need for extra metal. Have the battery disconnected. Don't push or pull the component too hard when youre about to desolder it. The solderingpoints on the mainboard is weak. I recommend to have soldered this component size some times before you try. And you should use microscope to see anything at all.
tarafından
Where is this same jumper on a iPhone 6 Plus ?
tarafından
Yorum Ekle
Here is a analysis about how this problem happens: Why iPhone 6 Camera Not Work after Screen Replacement
Puan 0
Yorum Ekle
I had the same problem with my iphone after i dropted it. So when i replaced it, it had the same problem. Maybe when you conected the ports may not be conected well. Or maybe the wires are damaged. I sugest to open the phone and look any lose wires. Or the wires are not compatable with the phone.
Puan 0
Yorum Ekle
first to try
reslod camera conecttor
After not don rear camera?
choos from Another iphone 6 ok . And
putt camera
Puan 0
Yorum Ekle
does anyone have have 6s camera fix with jumper method
Puan 0
Yorum Ekle
jumper solution on U2301 is not recomended best solution is replace the component ..
anyway this is only on issue for both camera error no for rear camera only.
Puan 0
Yorum Ekle
tks guys
I'll try replace this component or try a jumper
Someone Did the jumper and had any problems after?
Puan 0
Yorum Ekle
Yanıtını ekle
Jack sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 76
Her zaman: 117,297
