The engine cover is cracked, will this affect the performance?
I dropped my hammer on my engine and now the cover is cracked exposing the engine parts. Is this bad for the engine?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
The plastic cover on the top of the engine is mostly for appearances, so if it is cracked it should not be a problem. However, the middle section of the cover is designed to act as a small filter so that big items do not get in the engine, so if this portion of the cover is completely broken, you may want to think about replacing it.
Bu yanıt yardımcı oldu mu?
Only the corner is cracked so I'm guessing I'm fine. Thank you Mr. Wirtz.
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 39
Her zaman: 6,736
2 Yorum
Do you mean the top plastic cover, or the metal cover over the engine?
Tim Wirtz tarafından
I meant the plastic cover.
Taichi Nakahara tarafından
