Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
This graphing calculator was originally designed in 1995. The TI-80 has a large screen size 64x48 pixels and 16x8 characters display. Internally it contains a 980 KHz CPU and 7K RAM memory.
3 Soru Tümünü görüntüle
Why is the keyboard malfunctioning?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
The next most common problem with the power would be the physical button being either broke or stuck. In order to repair the button(s) remove the faceplate of the device and make sure there is nothing interfering the motion of the button(s) then reinstall the faceplate and test the problem button(s). If the faceplate has been removed and the inside of the calculator is clean then the next most common solution would be the replacement of the keyboard.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Jordan Dalgarn sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 66
