Ana içeriğe geç
The Seagate FreeAgent Go is a portable external drive by Seagate. It was released in May 2010.
10 Soru Tümünü görüntüle
hard drive never opens when plugged into computer
the hard drive turns on and lights up when plugged into computer but will never load or show up on desktop. Is a portable hard drive able to be fixed?
Bu iyi bir soru mu?
Puan 5
1 Yorum
My young 3 year old 3 TB Seagate external is unusable.
Windows reports it is failing during boot up but does not see it after booting.
Explorer and disk management do not see it.
It is spinning.
I have connected it from via SATA connections after removing the outside covers after the USB did not do anything.
If windows "sees" this drive during boot-up, and reports it is failing and to back up immediately, then how do I do that if after booting up it is not detected? So far I have not been able to access anything on it.
As far as part of the cause, I remember having windows do optimization (defrag) before the failure using Windows disk management and finding the pc stalled some hours later and after that the drive removed itself from existence.
If there is a method during boot when seeing the message the drive is failing so back up, what is it and why does the disk not show up if windows saw during boot?? Or I don't really need to know why, just how to fix.
I appreciate any clues or techniques because this drive is so young it should be working.
Oh, there is a noise about a minute after booting and the operating light at the bottom in the front of the drive comes on but then goes off even though it is still spinning.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Use your Disk Repair Utility and see if it can be repaired.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
You can use Disk Manager in Windows to see if it detects the external drive. Disk Manager is found by right clicking on the Start button and then click on Computer Management, you will see Disk Manager near the bottom of the list. Double click on Disk Manager and it will show all the storage (Drives) it recognizes. If the drive can be seen by Disk Manager then you can right click on the problem drive and then click on the Tools tab, click on Error Checking and wait for the error checking to complete. Sometimes, you may be prompted to reboot, this is when the drive is mounted by the operating system and needs to be unmounted to do the error check. Depending on the size of the drive, the error checking could take as long as a few hours to complete.
Disk Manager is a powerful tool and it is easy to accidentally remove a disk or reformat one. Do not make any changes to Disk 0 which is the primary drive that loads Windows. This method will work for USB thumb drives. If the system asks if you want to format a drive, select No.
Puan 0
Yorum Ekle
Yanıtını ekle
skillmanhixson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 1,834
