Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazı tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16,32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3994 Soru Tümünü görüntüle
How to sort screws without reference
Hey everyone! After being helped so well on my first question here by @Rany, i felt confident this was worth a try. As i said in my first question i am building a Iphone 5S starting with only the motherboard and the home button flex. I have every part, except the earthing clip but i have ordered that, and had a pre-installed 5S back housing with small parts, a original 5S back housing with all parts,a new lcd with all parts, 2 screw sets and a set of all small parts in a 5S. The parts, and mainly the screws, i need guidance on. How do i distinguish screws from each other? Also in my test run with everything installed, except the earthing clip ;), the phone does heat up quite a lot and the screen is a bit jittery but that i think is because the connector shield isn't on properly because i cant find the screw that's supposed to go in top right. I know that its supposed to be de-magnetized but i cant find one that is :( Sorry bout the long post Thanks in advance for any insight.
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
LCD iPhone Ekran Tamir Kit'leri
Ömür Boyu Garantimiz kapsamındaki bütçe seçeneği.
Shop Kits
Onarım maliyetlerini düşürün, kaliteyi değil.
Shop Kits
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The repair guides here will give you the screw size. A digital / electronic caliper will allow you to measure the screws and match them to their appropriate place.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorumlar:
Nice!Thank you for the solution! Any ideas on the over-heating? Also do you think it is essential the top right screw in the connector shield is non-magnetic?
tarafından
Yorum Ekle
Yanıtını ekle
hari sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 400
