Ana içeriğe geç
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
640 Soru Tümünü görüntüle
screen not responding after replacement with low memory - HELP!
I replaced digitizer and LCD assembly on a Galaxy S4. It seemed to work fine initially, but client brought it back saying it stopped responding. The areas where the LCD shows does not respond (even though when I just turned it on it started responding for about a minute then completely stopped), but the touch buttons on either side of the home button respond. I going to try to reopen the phone and unplug/replug the digitizer from the logic board to see if that helps but I have a couple of concerns. I noticed that the phone says that memory is low and that some system features may not work as well as another notice stating that storage space is low as well. Could low memory and/or low storage space cause the digitizer to stop responding to touch?
Anyone ever seen this happen before? Any ideas on how to resolve this, other than the obvious "get another new screen"? Thanks in advance for any advice given.
Bu soruyu yanıtlayın Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hey there, PCHookups.
Both of those problems could be caused by something not being properly attached if the digitizer cable and the connector for some of the memory weren't properly seated so I recommend opening it back up and double checking all the screws and cable connections.
Best of luck and let us know if that helps!
Spencer JR
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
PCHookups sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
Her zaman: 103
