Why won't my phone power on?
hai..i have lenovo s920..but the problem is cannot turn on but red light lighting when i connect to pc.is there have solution that can guide me.or my phone cannot been repair anymore?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
I dropped my lenovo S920 hard in the floor. When I turn it on it won't open. When I try to charge it, it's charging. Do you know how to fix it?
I dropped my lenovo S920 hard in the floor. When I turn it on it won't open. When I try to charge it, it's charging. If you're gonna ask if it's low bat, it's not. Do you know how to fix it? Please help me with this problem.
Bu yanıt yardımcı oldu mu?
First you have to check whether any short circuit on PCB, No shorting then you check the ON?OFF switch. any damage resolder or replace the ON/OFF button.
If there is no damage in ON/OFF button flash the device . again it won't power ON then reheat the cpu and check, reball the cpuand check, Replace the cpu and check. no solution now change the PBA.
U do all these things after check the battery output. and have to check oscillator outputs..
I have the same problem .. but I did not drop my phone ... I just woke up in the morning trying to open my phone and the same problem happened ....
i have a problem of s90 lenovo, it wont power on, but it vibrates and there's a red light besides the camera hole(front).will you help me how to fix?
i had the same problems .. but i manage to solved it.
download the stock rom and try flash it using SP Flash Tools .
your device will surely revive from dead ..
:D
What do I do ? I bought a phone from Lenovo then when it came I charged it for about 15 h then when i went to turn it on it didn't do anything so I charged it for 6 h and it still didn't do anything . It's been almost 2 days and it still doesn't turn on . I tried pressing volume + and power still didn't work I tried volume- and power still didn't do anything, I tried +and - and volume doesn't work . PLS HELP ME!!!!!
step 1 gather some strength
step 2 hold your phone really tight
step 3 smash it to the ground and say &&^& this.
what you need is you want to kill kids ( In Game ) until you’ve gathered sum POWER and then what you need is Flash your phone with stock ROM.
ENJOY :)
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 13,024
3 Yorum
My lenovo s90 is not working and it is not working and it is not oning.
abhishek garimella tarafından
i acquired a new lenovo k5ic78, i have tried to charge but it cant get switched on. what could the problem be?
andesent2004 tarafından
need help please
