Why won't my Lenovo A7-40 power on?
it was fully charged n it just stopped working and wont on
its been 3 days and it wont get on i tried charging it but it wont get charged
Bu iyi bir soru mu?
Bu iyi bir soru mu?
If it does turn on it pops up Reboot and some other stuff too
Bu yanıt yardımcı oldu mu?
Guys Just press reset button and then press power button..if you cant find the reset button just open the back cover en then you can press it with finger... Good luck
Check the battery. I opened mine and the battery didn´t charge anymore
I had such a problem
The battery just had been moved
I put it right and labeled it
It worked
If you can feel the motor is buzzing, try to check the lcd cable, many lcd cable faulty in this device, that`s my experience, or try to disconnect and put it back. If it`s not charging can be charging port issue or battery even motherboard. try to factory reset with the power button and the volume up button.
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 3,392
3 Yorum
I have a tablet and it turns on and you can hear everything but you can't see anything
Nicholas tarafından
I have this problem
playingsafeps tarafından
my lenovo won t open
wildalachica tarafından
