Ana içeriğe geç
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526 Soru Tümünü görüntüle
swapping i9506 board into i9505´s frame
See if someone come through some light on my problem...
The screen of my i9506 completely broke, aswell as the external frame that was very damaged. I bought an i9505 which didnt even turn on and I swapped the i9506 board into the i9505 case, rather than changing screens.
It works good, but i find a strange problem.... the phone works flawlessly until i put the screws in the back cover to leave it sealed, when it turns off and there is no way to turn it on again until i completely remove the cover and frame, to manually press the power little switch in the inside. Only then the phone turns on again.
In case it was due to differences in the rest of parts between i9506 and i9505 or due to any other problem with any other part on the original i9505, i swapped all internal parts from i9506 into the i9505´s frame, excepting the frame itself with its screen, but the problem wasnt solved.
I hope I made sense discribing the issue im having, and someone can think of a reason why the phone turns off as soon as i put the screws in....¿?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
1 Yorum:
same by me.
im in need of schematics for the i9506 as well!
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
Hola el chasis del i9505 es diferente al del i9506 y al cerrarlo la placa hace contacto en el chasis y por eso se apaga, la solucion es aislar la placa del chasis con cinta o con algo y no se apagara.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Comprendo todo!
Fue mucha ayuda!
Gracias!!!
Puan 0
Yorum Ekle
Put some Kapton Tape in the top left of the motherboard...Dont cover the antenna (gold clips) just the components around there...You will see the difference in the i9505.....extra components in that area which are touching the rear bezel...cover them and its will be sweet
Puan 0
Yorum Ekle
Cover the top left of the board with kapton tape except gold connectors....
Puan 0
1 Yorum:
canshow me the picture plz ?
tarafından
Yorum Ekle
where top left
Puan 0
Yorum Ekle
Yanıtını ekle
Wlod sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 3,438
