Ana içeriğe geç
1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
192 Soru Tümünü görüntüle
MacBook Air not charging, not turning on
Hi,
the Macbook Air 11" Mid 2011 is not charging the battery. The light of the Magsafe connector is always green. The computer will not start up with the Magsafe Poweradapter connected.
What I have tried so far:
  • used other power supply
  • replaced battery
  • reset SMC
  • reset PRAM
  • upgraded to Yosemite
After the battery change the computer will start up. But the computer will not charge the battery and the battery will run down even when the charger is connected.
Do you have suggestions on what I could change/check? (IO Board? Logic Board?)
Christian
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Hi Christian,
I'd definitely check the I/O board first. It looks like the power from the charger isn't reaching the MacBook. Check the I/O board cable.
If that doesn't help, I'd also check the battery. It's pretty unlikely though, because the MacBook should run off external power if a charger is connected, no matter if a battery is available or not. But you never know.
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
Thanks! I will check the cable and the IO Board.
Btw, with a multimeter do I have any luck in diagnosing the problem? I would probably just switch it but it is not so easy to find one in Germany.
Christian
tarafından
Same problem here, did you get to fix it?
tarafından
Same problem here. Did you get to fix it?
tarafından
Yorum Ekle
Hey Christian,
Am facing the same problem! Did you get to fix your MBA?
Tyson.
Puan 0
Yorum Ekle
Yanıtını ekle
Christian van der Leeden sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 579
