Ana içeriğe geç
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Soru Tümünü görüntüle
Recently, the CPU fan started running at full speed. What is wrong?
The CPU/Video fan runs slow at startup, and gets ridiculously fast and loud after a few minutes.
I disassembled the computer to remove 3~4 years of dust on the heat pipe fins, but the problem remains.
It is the nVidia logic board GPU that is running at 160 deg F. It has the CPU/GPU fan running at a full 3600 RPM. Is this in spec or am I going to need to try to re-seat the heat pipes to get a better thermal connection?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
did you replace the thermal paste on the cpu/gpu?
i had a few macbooks with heat problems, the paste was hard and almost useless - in other cases, there was way too much of that stuff on the chip's (original apple!).
replacing it is a must!!
Bu yanıt yardımcı oldu mu?
Puan 5
5 Yorum:
+ although nick recommended the thermal paste first, I'm gonna uptick ya. LMAO
tarafından
no, he edited it in his answer after i wrote it - as always (check the history - but i think he will delete his post soon - also as always)
tarafından
you are aware that everybody can see the "edited by" and of course the history of a posting.
tarafından
@ Markus...I was being sarcastic. LOL
tarafından
;-) and nick, it's not that "I" have a copyright on the stuff i'm writing. but it's lame to edit the stuff of an answer in the own answer - only to - yeah - only to what ? get a better reputation score? it's like the deleting stuff that you always do - i delete my answers if the worst case happens and mayer, majesty and answer at the same time - like a few minutes ago.
tarafından
Yorum Ekle
Try downloading a demo of iStat menubar.
Then you will get a good look into the CPU processes and temperatures in your iMac.
heres the program
Puan 1
2 Yorum:
If you'd given a link you'd have gotten an upvote.
tarafından
i edited this with a link
tarafından
Yorum Ekle
You could also try Activity Monitor, which is included with OS X.
Puan 0
Yorum Ekle
Yanıtını ekle
Jeff sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 2,541
